kscapeaustria
Hello Kaleidescape forum!
I have recently purchased a used KSERVER6000 but apparently it's been set to use a static IP address. So I came across this forum to find the two methods to access the server and reset it to DHCP: via a temporary local-link address and via the serial connector. After failing on the local-link method, I purchased a crossover serial cable, hooked it up, and found it not reacting to any commands. Now I am desperate since I've run out of ideas what to do. What worries me the most, though, is that when I connect it to a router, neither the network LED on the router nor the one on the server lights up. The front of the server, however, glows blue whenever it's powered on, even if it's not connected to anything. Do you think it's a hardware problem?
Thanks a lot in advance,
Sebastian Kovats
Sebastian Kovats
