KPlayer 6000 - Reset factory defaults
20hertz
I recently bought an used KPlayer 6000. When I connected it to my system, I get blue lights, but there is nothing displayed on the screen and when I tried to add it as a component to my system, it did not show up in the Add component section.
I wanted to try resetting the player to factory defaults to see if it works before returning it, but I am not able to find the information for this.
How do we reset the kplayer 6000 to factory defaults, which would hopefully reset the network settings if any as well?
Thanks for your help.
I'm not seeing the master reset, but the important one looks to be "01/1/SET_NETWORK_SETTINGS:0::::::". If you skim the manual you should be able to change anything else out of line or find the status of problem.
If you aren't seeing activity on the network port, this will likely involve diving in via serial.
Thanks for your quick response.
The problem is I do not know the IP address as the player is not showing up in my browser interface nor in the the Add components page.
This is why I wanted to reset my network settings, as I suspect the previous owner may have had static address, which was not changed before they sold this.
All Kaleidescape devices send out a UDP heartbeat on port 440 every second, and in doing so, any server on the network will detect ANY Kaleidescape device regardless of the IP address. To see a list of all Kaleidescape devices on the network, try accessing the lskd.html page ("lskd" stands for "list of Kaleidescape devices").
http://<server_ip_address>/lskd.html
This is a super useful page that loads quick (there is no waiting for the GUI to appear), and displays all relevant network info for each device regardless if there are multiple systems, or if there are orphaned devices that have never been added to a system... the SGID column indicates what components belong to what other components. If the player does not appear on that page, then there is likely another problem (likely it is not properly connected to the network, or it is failing to boot).
If you are confident the player is connected to the network, then observe the player's behavior after plugging it in. The front bezel will illuminate a bright blue when first plugged in, but after about 45 seconds, it will dim to a lighter blue, or it will turn amber if booting successfully. If the front bezel light never changes, then likely the player is not booting. If it dims to a lighter blue, then it is booting with either a DHCP address, or a previously assigned static address. In either case, the player will appear on the lskd.html page, meaning it will also appear on the components page where you can change the IP address to DHCP (or a different static address).
If the front bezel remains a bright blue, then it is failing to boot, and likely has a faulty main board.
I hope this helps!
Thanks for all the help. Much appreciated. It doesn't seem to work. It stays bright blue all the time and the does not show up in the lskd page. I guess it is going back.
