I am trying to replicate a disk set from my old 3U Server to my New / Main one.
Everything went well until I got the replication started.
Every title shows transfer interrupted or failed. It usually attempts each title 3 times and then moves on.
I was going to cancel the replication and start over, but the source Server has disappeared and I can't gain access to it.
I know my destination server sees it, because I get the message at the top of the user interface prompting me to see another system or add a component.
When I click on either of those links, there is nothing there.
If I shut off my source Server, those messages go away.
I've tried the simple stuff assuming a network issue: replace the cat6 Cable, Switched the network port, I even replaced the source server with the Replication disks moved into another Server unit and I'm stuck.
I have no access, The replication has stalled and I can't get in to it, stop it.
Also, I can no longer access the user interface of the source Server. Although I could before the replication attempt started.
Anyone have any ideas what I did wrong or what to do about it.
