So I ran into an issue today that I believe would rarely happen, but I'm not sure the best way solve.
Found a double feature DVD for less then $1. Disc was recognized but not cataloged by K.
Movie A is in the store with D2D, movie B is not in the store. I purchased the D2D and downloaded movie A.
They plan was to edit the import to just be movie B, so that i would have two separate entries: Movie A downloaded and movie B where play disc was the only option and I would have to manually select movie B.
Unfortunately, the physical import cannot be selected unless I select the download movie A and then select other versions - DVD. I give it about a week before I completely forget I own movie B.
The only options i can came up with was delete the download and have a dual entry title, rip the disc, delete movie A and reimport as an unknown disc, or send the disc in for cataloging (so not worth it for movie B!)
Not critical in any way, but just an interesting side effect of other version
