Instructions for Opening Alto?
JWort93
Does anyone know the proper method for opening an Alto? Have an older Alto that I'd like to open up and clean/dust out, but I can't figure out how to open it up lol. Tried removing the screws on the back of it, but nothing seemed to move after I did that. Feel like I'm going crazy, but I don't see anything obvious and don't want to damage it.
I would have to find the file that K sent me but the back panel is covered in an adhered label that you need to remove to get to the screws to open the case.
It's actually quite easy. You just start prying it loose from one side and it will come off. The adhesive stays on the label and you can reattach it.
