Home Router Recomendations
SJHT
We have a fairly large home network (80+ devices mostly wired). I use several Dell business class switches across parts of our home. Any recommendation on routers? I would not necessarly need wireless as this is handled with separate access point setup. Ideally the router would have QOS for internal network routing/prioritization (vs. only QOS for Internet usage). My switches allow me to prioritize K equipment (we have 2 Stratos, 2 Altos, 2 Terras, 1 DV700). I would like to have routing priority as well. Currently using a TP-Link router and have had a few issues. Thanks for any suggestions!
jbm007
We use Luxul in all our systems we setup. ....... No problems.
In my opinion stay away from all forms of "gaming routers".
SJHT
Ive been looking at these. Which models are you using and do you also use their switches? I might start with just replacing my router. Thanks for the feedback. SJ
SJHT
Appreciate the help. Think I will go with that one. I spoke to the Luxul people at Cedia a few years ago. Nice team. Thanks. SJ
I have just ordered the Ubiquity dream machine pro and the Ubiquity PoE 24p & 16p Gen2 switches. Several good reviews, great looking interface and the security/firewall features helped me with this choice. I will give it a try, can always return them if not convinced
SJHT
Yeah, I looked at that. The interface looks pretty slick. I’m also maybe looking at replacing 2 of my switches (both have K equipment). We have our main hub for the house, but also a large secondary area. The Luxul switches allow you to “stack“ them with 10GB SFP cable between and manage as a single switch. The managed interface looks much more straightforward than the Dell switches I‘ve been using. Thanks for your suggestion. SJ
mpierson
Thinking of going for the same. The interface and control it offers looks great. Be interested to hear how you find it. (y)
fritzcurtis
I have all Ubitquiti and 5 access points throughout house. Really great stuff. Will not be disappointed
fritzcurtis
The remote capability is awesome. You are able to reboot not only a switch, but down to a specific port.
fritzcurtis
I am part of their early access program, so I beta test a lot of product. Cameras, switches, routers, etc. I replaced all my Pakedge equipment with Ubitquiti. It is a little funky setting up as the controller has to be run separately, but once you set up, it is awesome. all online support and similar to this forum, the guys are great.
jbm007
Just remember some of these switches are managed switches. If you are not familiar with this type of switch it can be interesting.
Great equipment though. Reasonably priced.
JohnE
The Dream Machine Pro that was mentioned has got the controller included. I got the normal Dream Machine and quite pleased with it.
Exactly. Just read the posts but I went for the Pro for this reason. And the Ubiquity Threat Management seems to be highly efficient. I plan to install everything before this weekend. Will let you know.
