Resource icon
HDR vs. HD Script Aug 6th, 2019
No permission to download
JohnJ
JohnJ submitted a new resource:
HDR vs. HD Script - script_HDR_vs._HD_6Aug2019
Downloads (as of 1 December 2019): 7
Here is a Script that has the exact same scenes from both the HDR version of a moive and the HD version of the movie. I use it in tweeking my Lumagen Pro Dynamic Tone Mapping (DTM) but it is just a nice Script to see the difference HDR makes.
You need to have both versions loaded to the same Starto/Terra system for it to work. Also, there are some custom scenes that will be loaded automatically when you load the Script.
Read more about this resource...
josh
Great idea for a script! But it sucks that in a co-star paired system a script can't pull scenes from the premier line. All my SD/HD movies are on premier server, so the script won't work in my case. :(
JohnJ
Yes, I had to load these movies onto my Terra in order to have this work. Luckily, I had the space.....
