After years of getting my system set up and working just right, we are unexpectedly looking for a new home. The home we are looking at has a centralized rack and runs HDMI over Ethernet to the various displays in the home. None of the displays are 4K, but I plan on changing that for 2 prime areas. There is also a theatre which seems to be wired the same, as there are no source components in the room nor much room for them. The projector is a Wolf Cinema circa 2013 or 2014 but I cannot see which model it is. I would like to go 4K HDR (maybe one of the new Sony PJs). There are Ethernet runs to the two display areas I am concerned about, but I do not know for the theatre other than to the projector itself.
Can the Strato or the Co-Star set up work like this? Are there 18Gbps HDMI over Ethernet products that would do the job? I believe the Premier system, if kept separate (no Co-Star) would be OK like this. I have always tried to keep my sources close by for short wire runs, HDMI or otherwise, so this is all very new to me. I am not sure what pre-wiring is present to allow connection of sources in these rooms should I try to change things.
Thanks for any assistance you can offer.
Wayne
Wayne
