McintoshMike
- Joined
- Feb 2, 2022
- Messages
- 8
That's why the prices for the used disks are so low, especially in times of the crypto hard drive mining possibility. I only can suggest you try to use any online hard disk recovery services like raid recovery service and try to recover the required software on disk. Have a great day!Well, you need the proper software to make these disks work. If I remember it right, most of the hard disks of these series have special encryption, so they didn't work at all without proper software.
Do you own a player?How do you find disc and load it on box?just picked up KServer 2500
Yes I have 2500 k server and m500 right now.it in,t has 1 TB drive want to put in 4 6tb drivesDo you own a player?
You will need both to have a functional system.
Have you tested the server to see if it functions correctly and if the hard drives are still viable?
Players and vaults work differently, so you'll lose the ability to play without importing, catalog, and all-around the alternative option for trying to import discs that have issues in the M700 (either from a poorly authored copy, long duration, or just optical drive quirks.) Having two players also lets you go Costar without losing music playback. I wouldn't get rid of the M500 unless you were certain you'd be okay with all of that, even for a single zone.Your m700 is a player as well. so you have two players.
If you're only using it on a single room, and your rack has the space, I'd be using the m700 as the player since it can also load/import DVDs, CDs, and Blu-Rays. your m500 is only a player. Could even sell it if you only intend on having a single zone system.
