Should just be the reset pinhole mentioned in Jim's post above.Also, following up is there an easy way to do so for 3u k-5000 servers? Specifically, resetting from static ip to DHCP.
Thanks for starting the 'Replacement Parts Thread'. Unfortunately the 3rd party "UT Technology UBS-003" for the Alto/C1 G2 that a user found didn't show up in there. I've had no luck searching site. Checking to see if you or anyone have any solutions for replacing this drive?I think a member found a replacement online from a 3rd party, but I don't recall the thread. Our search capabilities leave a lot to be desired unfortunately, and folks don't always post a separate thread when they find a replacement part (which I usually request to make it easier to locate).
I'll start a separate thread where members can post replacement parts info.
