Crestron connection puzzle.
9riffTX
I found this connection dangling and looking for hints as to where to reconnect. It is labeled projector, so an output would make sense. The control interface screen is blank i am looking for hints. Thanks!
8ADD99BA-9879-40C4-B09B-D4A4E2F51530.jpeg852921C9-B385-45FD-9A16-00C270B30F61.jpeg52642936-5358-45C9-9515-B16A1EF94961.jpeg
Kevin D
It most definitely goes into S5 infrared, but that's not going to fix the blank screen.
9riffTX
That’s what I did. Unplugged and plugged power back in. Screen wakes up but says blank.
Just when I got everything else ‘working,’ again.
I wonder how many remotes I can find…
9riffTX
Update: The tablet came back to life but the display blacks out, intermittently.
It seems to be stuck in a loop sending ‘volume up’ commands, with no regards for the health of the amps and speakers. thankfully, breakers do their job, but it makes the system inoperable. If you look at the screen gui, the volume up engages like it is being pressed, repeatedly.
Power-cycling doesn’t seem to improve the situation.
Not sure how to make it stop banging it’s head on the wall, or me.
TIA
