I was aware of that. My question, which I must have not asked properly is this: I have a script to which I wanted to add a couple of scenes from your newest script. I was asking how I can move (or copy) 2 or 3 some [some more automated way] of the scenes from your most recent to one of my existing.If you download the script it will only include the movies on your system. It does it for you.
I deleted and downloaded once again. There was a custom scene on my system already from a previous script. Same X. Aliens as well. Enjoying the others!View attachment 5167
I need the format decoder ring.
Downloading again - 4K HDR 10.
Thanks!
Update....
You can create your own scenes and use them in your scripts. I guess that´s what cineramax did.Am I looking at the correct movie called "The Wave" as I don't see a scene called "Cave in"? Does the K website not show all the scenes? That may be the problem. Do I need to download before being able to see all the scenes?
