Chowmein driver Control4
jsprung
I just added an M300 so I can get music back since upgrading to a Strato system using Co-star. Will the Chowmein driver allow me to “see” both systems independently. In other words, can I have a “Music” and “Movies” as separate choices and the Chowmein driver will work with both of them or do I have to choose one or the other?
-Jason
Yes. You can have multiple versions of the driver present/added to the system. I believe it needs to be the original Chowmain driver and not the newer version. One driver is set to the IP of the Strato Co-Star. The other driver is assigned the IP of the Premier Server and would only be used for Music, hide the movie side in Composser. You could name one driver Movies and the other Music.
