Hi all -
I'm looking to purchase a Strato V (and 22TB Terra Prime Compact) in the near future. Right now, I'd simply look to hook it up to my existing Samsung TV (can't remember the exact model number, but it's a couple of years old, 65", 4K, and was about $1500), but next year we will be moving into a new house that has a basement, part of which I am considering using to create a (small - around 3m by 5m, and the ceiling is low) home theater room.
I see from the main forums that there are quite a few compatibility issues and challenges with the Strato V right now, and I guess it's safe to assume these will be addressed with firmware updates by the time I build out my room.
What I'm after is advice from those who have a Kaleidescape system as to what they would recommend pairing it up with. My budget is somewhat flexible, but I'm thinking of $5-8k on the display side, Marantz Cinema 30 for the AVR (happy to be guided differently here, but not blow the budget completely), and $10k or so on speakers. So I guess that comes to around the $20-25k ballpark excluding the Kaleidescape bits.
Assume room treatment budget will be dealt with separately.
It's been many many years since I last had 'proper' home cinema kit (I used to have a full Meridian system back in the 2000's) and am completely out of date with the current tech, and I must admit somewhat confused about all the different speaker configurations there are these days.
All advice and suggestions very much appreciated - thanks in advance!
Kind regards,
Gerald.
Kind regards,
Gerald.
