Ability to build playlists without other privileges
richard
Hi
On my kaleiedescape I have 5 Music playlists ("collections") (one for each member of the family) that auto-sync using Conductor into the family member's individual logins on whichever PC they normally use which then sync to our iPhones/iPods/iPads.
The trouble is the family members can not manage their own playlists, because if I give them the password to the UI for playlist management they also get the ability to alter the parental control settings and delete movies/music etc by mistake.
I would therefore like a 'lower level' login (probably without a password since individual UI logins would be asking a lot, but perfect) that can be enabled to allow users to add/delete stuff from the playlists that appear under 'My Collections' in the Music UI.
This idea may also be extendable to the Movie UI of course.
Cheers
Richard
