Alright so I got a 5u server and on power up all the lights come on for about 5 seconds then turn off so it looks like the power supply is gone.
So if I get a power supply that is 470 watts and has the connectors I need it will work right? I have identified these are the connectors that were being used (1-24 pin, 1-4 pin 12v and 4 molex).
I have seen a few on ebay with the correct plug orientation so just want to make sure I got this understood correctly before I make a mistake.
