1U Server Power Cord Length?
Kicker
What is the length of the standard power cord on a 1U server? I looked through the install guides and spec sheets and couldn't find it. I'm assuming some of you know this off the top of your heads.
Thanks!
Thanks!
Sounds like for some reason you need something authoritative, and since I don't own a 1U server that I bought new I can't say, but I'd bet it's a pretty standard 6' cord. It's just a normal PC power cord, and I'd bet you pretty much ANY of those PC power cords will work, since even the minimum rating for one should be enough juice for a 1U.
--Donnie
Correct, any standard 3-prong PC power cord will work. I cannot remember if the enclosed cords are 5' or 6', but suspect 6', but I've substituted 3' foot cable on many rack installs to conserve space, purchased at Monoprice for about $1.50! (They have shorter and longer power cables as well.)
