Reply
  #1
Old Aug 9th, 2018
iansilv iansilv is offline
Senior Member
Default Screw size for attaching rack ears to m700?
So as the little voice in my head told me I would when I didnít tape the bag of screws to the rack ears when i took them off, I lost the screws to mount the rack ears to my M700.
Anyone know what size and type of screws I need to attach the rack ears to my M700 so I can order them from somewhere?
  #2
Old Aug 10th, 2018
AlienWarlock AlienWarlock is offline
Senior Member
Default
Not sure if this helps but the M500 ears use a #6-32, 1/4" long flat head screw. You should be able to find the screws you need at any hardware store. The big box stores have bags of screws in most sizes. My local Ace hardware has a large assortment of Hillman Group fasteners in drawers that are sold individually. They are not the best deal, but they are a great resource when I need just a few very specific types of fastener.
  #3
Old Aug 13th, 2018
Croptop Croptop is offline
Senior Member
Default
The screws used to mount the rack ears on an M700 are M4 x 6mm, flat head, black.
Like these (but black):
https://www.homedepot.com/p/Everbilt...2988/204274524
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
