Reply
  #1
Old Jan 22nd, 2018
audioguy123's Avatar
audioguy123 audioguy123 is offline
Senior Member
Default How to disconnect link from my Alto to the K-Store
I am in the process of deleting all of the movies I had on my Alto in preparation for shipping to the new owner. But how do I disconnect this unit from the K-Store so the new owner can't reload the movies I deleted or purchase new ones on my credit card?
__________________
Our Theater
  #2
Old Jan 22nd, 2018
Montucky Montucky is offline
Default
If I'm not mistaken, I believe you will go to your K's IP using your web browser. Typically 192.168.1.[insert ip here]/components. From there you'll have the option to "Remove from system" any individual component. I'm not sure, but perhaps a factory reset can be accomplished as well?
  #3
Old Jan 22nd, 2018
mbmapit mbmapit is offline
Senior Member
Default
Quote:
It's in the GUI settings:
1. Press the Menu button on the Kaleidescape Remote, or press Menu on the Remote Control page of the Kaleidescape iPad App, or press the Kaleidescape logo in the top left corner of a touch panel using a Kaleidescape control template.
2. Use the arrow keys to highlight System, then select Settings. The Settings page appears.
3. Move down the screen and highlight Activation.
4. Select Deactivate player and then confirm by selecting Deactivate.
5. After the player is deactivated, the Reset Settings and Erase All Content option appears. Select this if you are selling the player and the new owner does not own the content.
NOTE: If all content is erased, the content no longer appears in the on-screen user interface in a matter of moments, but depending on the amount of content, it may take several hours for the space to become available.
  #4
Old Jan 22nd, 2018
Senior Member
Default
Thanks but I must have a different iPad app because the options you listed are different on my version.
I have wandered around various pages and deactivated the system and am manually deleting all of my listed movies (those that still show as BluRay even though I removed them from my Vault). I already deleted the BR equivalent that I had downloaded from the Store.
__________________
Our Theater
  #5
Old Jan 22nd, 2018
Senior Member
Default
Just go to system settings activation then reset. Erasing movies individually is ridiculous and a huge waste of time.
  #6
Old Jan 23rd, 2018
20hertz 20hertz is offline
Senior Member
Default
do you have to delete the movies? I thought once you deactivate, the movies cannot be played until activated. Even after activation, only the movies linked to the account that activated it or to the activated account's linked UV account is playable. Others cannot be played.
This might be a better option when selling units because the other user need not download the movies again. Is this not the case?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
