Reply
  #1
Old Dec 12th, 2012
bedbuged bedbuged is offline
Default Can a set of 2 disks...
I have a set of two(2) 2tb disks for sale in the marketplace. I didn't have them re-initialized. I know they can be placed in an empty 1u chassis as-is and be used without having to re-initialize them. I know they must be kept together because they are married to each other right now... but can they be added to another file system if someone already has other disks in their server?
  #2
Old Dec 12th, 2012
Croptop Croptop is offline
Senior Member
Default
In order to add those disks to an existing filesystem, they would have to be reinitialised.
  #3
Old Dec 12th, 2012
Default
Thanks
  #4
Old Dec 14th, 2012
Transepoch Transepoch is offline
Senior Member
Default
Or someone could add at least a pair of blanks [spares] to run a 3U.
  #5
Old Dec 17th, 2012
Mr.Poindexter's Avatar
Mr.Poindexter Mr.Poindexter is offline
Senior Member
Default
You mean a 1U. You cannot take a 1U set of drives and run a 3U chassis with them.
  #6
Old Dec 17th, 2012
Senior Member
Default
First I can recall hearing of that limit, but glad it's coming before I bothered trying to integrate a 1U into my setup with the expectation of a direct-path upgrade.
  #7
Old Dec 17th, 2012
Senior Member
Default
Quote:
Actually, you can. You simply need to add a re-initialised disk cartridge to the disk set which will become the hot spare. For example: take a two-disk filesystem from a 1U server and put it into a 3U chassis along with a re-initialised disk to act as the hot spare and you'll be fine. The same would be true of a three- or four-disk filesystem as well.
  #8
Old Dec 20th, 2012
Senior Member
Default
Wow, that is news to me. Cool feature.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
