Reply
  #1
Old Jun 2nd, 2018
Mac.Concierge Mac.Concierge is offline
Junior Member
Default KVAULT10 error 501
Does anyone know what Error 501 on the K-Vault 10 mean & how to fix it?
Got a new to me K-Vault 10, power it up, got the error 501.
  #2
Old Jun 4th, 2018
Croptop Croptop is offline
Senior Member
Default
501 is "Front loading slot sensor is blocked". So either a disc is blocking the slot or something internally is obstructing the sensor.
You should be able to remove the "roof" of the vault (the circular disc on the top of the vault) which would allow you to take a look inside the vault. However, if you've already got a bunch of discs in the vault then this won't do much good and a full disassembly might be required.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
