Reply
  #1
Old Apr 14th, 2018
flitebynite's Avatar
flitebynite flitebynite is offline
Default Obstruction issue in an M700
I am having a problem with an M700.
I don't receive an error code, but there is a message displayed on the front panel.
"Check insertion slot for obstructions. Remove disc or press OK to restart vault"
There are no disc's in the unit and I have checked the slot for obstructions and I have cleaned the rollers. I don't see any issues.
I have also restarted the vault to no avail.
I have gone to the support section of Kaleidescape's web site and I don't see anything related to this.
Does anyone have any ideas of what the issue might be?
Thanks in advance for your insight.
Chris
  #2
Old Apr 18th, 2018
Default
I found a loose connector on the lower level.
Problem solved.
  #3
Old May 1st, 2018
brodricj brodricj is offline
Senior Member
Default
Did you need to open up the M700 to discover that?
  #4
Old May 2nd, 2018
Default
Yes,
There was a connector on the lower level tray of the Motherboard that was disconnected.
Very invasive. But, pretty straight forward.
Chris
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
