Reply
  #1
Old Mar 18th, 2018
cinelife cinelife is offline
Default Question for Some Owners
I've been asked to gather info regarding the time it takes to switch sources when using the following components. (If you have these components and can time the switching, it would be very helpful.)
Sony 5000ES Projector
Lumagen Pro (any model, but 4242, and 4442 primarily)
Trinnov Altitude audio processor
Strato
Optional components
Co-Star Switch
Premiere Player
UHD Player
1. Cable info: Make, length, any extenders/signal boosters if used
2. When you first power "On" the projector, does Strato display immediately, if not, how long to see OSD?
3. When you select a UHD movie, how many seconds before image is displayed? Does audio play before video?
4. If you stop a movie playing from Strato, how long before the OSD appears in this chain: Strato>Co-Star>Lumi Pro>Altitude>Sony 5000?
5. What are the switching times when you switch from watching a BR movie on Premiere to a UHD/HDR movie, and the reverse, when changing from a UHD/HDR to BR movie. Question assumes you have a Co-Star.
6. Lastly, if you are not using the Lumagen, and are using the Trinnov Altitude as your switch, what switching times are you seeing under the circumstances indicated in the above questions.
Any other performance comments you would like to pass on....
Thanks guys, I'll be collecting this info over the next 2 weeks, and will close the thread when complete.
  #2
Old Mar 19th, 2018
Default
If it makes it easier, you can shortcut the answers and just describe what timing delays you experience when switching between different content (i.e. HDR to BR, and BR to HDR) when using the Strato/Co-Star/Lumagen/Sony 5000. We're asking because several owners have mentioned to me they are seeing very long switching times when using the above components, in excess of 20 seconds in some cases. I've been asked to gather data.
Thanks,
  #3
Old Mar 19th, 2018
Montucky Montucky is offline
Default
It may or may not be relevant, but what control system is being used? Have you gone through the programming? The delays could lie within the macros.
  #4
Old Mar 19th, 2018
Default
Absolutely correct, but no one has replied to the request at this point, so I have no way of knowing if the control system is a factor, but to your point, the owners may not know either so your comment could be helpful. I'm gathering comments to determine if one specific component, or multiple components, is/are responsible for some of the long switching delays reported by many owners of the system described above.
  #5
Old Mar 19th, 2018
telem's Avatar
telem telem is offline
Senior Member
Default
Quote:
Jim,
I own all of the above and I will revert sometime this week.
  #6
Old Mar 20th, 2018
JohnJ JohnJ is offline
Senior Member
Default
Strato
Optional components
Co-Star Switch
Premiere Player
UHD Player
Hi Jim,
I don’t have a Trinnov Altitude audio processor but thought I would take same measurements for comparison.
Set-up:
Projector Sony VPL-VW5000ES
Video Processor: Lumagen Pro 4446 (use Lumagen for source switching and send audio from Pro to Audio Processor.
Cable from Pro to VW5000: RuiPro fiber cable – 20 meters
Alternate cable: Monoprice SlimRun AV fiber cable – 50 feet (not used for the measurements below but I have used with no issues)
Audio Processor: McIntosh MX160
Sources:
Strato paired to Co-star and M300 player (connected to 3U server)
M700 connected to 3U server
DirecTV C61K 4K Client
DirecTV HR21
Oppo Digital 203 UHD player
I fired up my trusty stopwatch timer app and below are the times that I get.
Times when switching between inputs (all time in seconds):
HR21 to Strato: 2.3
HR21 to M700: 2.7
HR21 to C61K: 9.3
M700 to Strato: 2.4
M700 to HR21: 2.6
M700 to C61K: 8.2
Strato to M700: 2.4
Strato to HR21: 2.7
Strato to C61K: 7.8
Strato to Oppo: 5.7
Times to video and audio:
Strato HD movie: Audio: 9.6 Video: 5.4 Total: 15.0
Strato HDR movie: Audio: 10.9 Video: 5.2 Total: 16.1
Strato scene HDR: Audio: 10.6 Video: 6.1 Total: 16.7
M700 HD Movie: Video: 6.0 Audio: 2.0 Total: 8.0
Power on Projector until OSD of Strato: 28.0
Stop watching HDR movie until OSD of Starto: 13.1
Note: On Starto, audio always comes first and then video.
On 3U, video always comes first and then audio.
Note 2: On Lumagen Pro, I use the “Menu 0874” which the description says “0874 - Set output as 4k50/4k59.94, 18 GHz max, based on input rate, with rate match off” and should reduce switching times.
Let me know if you have any questions or if there is any other data you would like me to take.
  #7
Old Mar 20th, 2018
Default
Thanks John, that's a lot of work, and very helpful!
The only two systems I've looked it appear to have similar numbers, plus/minus a couple of seconds. I'll wait to see what Kostas has as well, and there are a couple of others that are responding by email. All of them own, at a minimum, the Lumi Pro, Strato, Co-Star, Premiere and Sony 5000, a couple also have the Altitude.
I appreciate the help!
  #8
Old Mar 23rd, 2018
telem's Avatar
Senior Member
Default
Strato
Optional components
Co-Star Switch
Premiere Player
UHD Player
Hi Jim,
Projector Sony VPL-VW5000ES (4.506 firmware)
Video Processor: Lumagen Pro 4449 (Beta 021018)
1(18Ghz): Oppo 205
2(18Ghz): Strato C paired to Co-star and M700 player(connected to 3U Server)
3(9Ghz): Swisscom TV UHD (IP TV)
4(9Ghz): Roku Utra
5(9Ghz): PS4
6(9Ghz): Xbox X
7: empty
8: empty
Output 1: Audio only -> Trinnov Input 3 for Audio pass-through.
Output 2(18Ghz): Video only to VW5000(Input 2) using RuiPro fiber cable – 15mt/50ft
Audio Processor: Trinnov Altitude 32(with the upgraded HDMI board)
1: SKY HD(satellite receiver)
2: M300 connected to 3U server(mostly used as music player)
3: Lumagen for Audio past-through
4: OTE TV(satellite receiver)
5: Apple TV 4K
6: Empty
7: Empty
Output 1: Empty
Output 2: Video to VW5000(Input 1) using Monoprice SlimRun fiber cable – 15mt/50ft
Below are the switching times. I left outside the game consoles.
Times when switching between Lumagen inputs (all time in seconds):
Oppo to Strato: 16.9
Oppo to Swisscom TV: 1.4
Oppo to Roku: 10.1
Strato to Oppo: 6.6
Strato to Swisscom TV: 1.2
Strato to Roku: 9.2
Swisscom TV to Oppo: 1.9
Swisscom TV to Strato:7.3
Swisscom TV to Roku: 10
Roku to Oppo: 13.3
Roku to Strato: 9.6
Roku to Swisscom TV: 10.1
Times when switching between Trinnov inputs:
Sky to M300: 7.7
Sky to OTE: 10
Sky to Apple TV(HDR Mode): 14.3
M300 to SKY: 9.8
M300 to OTE: 10.2
M300 to Apple TV(HDR Mode): 14.4
OTE to M300: 7.6
OTE to SKY: 9.9
OTE to Apple TV(HDR Mode): 14.1
Apple TV to M300: 10.4
Apple TV to OTE: 12.4
Apple TV to SKY: 11.4
Time when switching between M300(Trinnov) and Strato(Lumagen-Co-Star)-OSD: 23.1
Time to video using Co-Star:
Strato C HD movie: 14.4(movie stored in Premiere) – 16.9(movie stored in Encore)
Strato C HDR movie: 23.6
Strato C scene HDR: 22.12
I hear audio 4-6” before seeing the video.
Switch from watching a BR movie on Premiere to a UHD/HDR movie:22.1
When changing from a UHD/HDR to BR movie:19.8
Time to video: M300 connected to Trinnov - HD Movie: 10.6
Power on Projector until OSD of Strato (everything on but the projector): 38
Power on Projector until OSD of Strato (everything off): 46.2 but sometimes close to 1’
Stop watching HDR movie until OSD of Strato: 16.7
Stop watching HD movie stored in Premiere until OSD of Strato: 16.3
Stop watching HD movie stored in Encore until OSD of Strato: 15.9
Let me know if you have any questions or if there is any other data that you would like to have.
  #9
Old Mar 28th, 2018
CINERAMAX IOPH's Avatar
CINERAMAX IOPH CINERAMAX IOPH is offline
Senior Member
Default
We will need to start a thread like this when the samsung the wall comes out. Thus Far going by their existing lcd wall system pretty quick.
https://youtu.be/4y_toBqagfA?t=58
Here is my client mr. blofeld's opinion.
https://youtu.be/9cW-D5Mj2ZU
But getting back to the topic of the 5000, At Hyperion in Istanbul we solved every hdmi issue fed from trinnov using Metra/ethereal high end copper cables with their hdmi extender.FWIW
  #10
Old Apr 1st, 2018
Default
Thanks K! Very helpful as well. These times are very consistent with those reported by several others outside of this forum. Still trying to determine if these extended video delays are the fault of a particular component, a combination of components, or HDMI/HDCP related. If we figure this out, I'll post our findings.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
